Error when launching the Rhino Plugin
Hi, I have followed the guide to install the one click LCA plugin (1.4.2) on Rhino 7. However, when I open the plugin afterwards, the following error messages appears and the plugin shows up without any contents on the drop-down boxes.
I have tried to troubleshoot this problem by re-installing the plugin both through the package manager and manually, updating Rhino 7, trying it on Rhino 8 (which yielded the same results), trying on a different laptop/account, installing through the .rhp file with no success.
Please advise on how to fix this problem, thanks!
Here are the remaining error messages since i can only post one image per discussion.
Hello. Thank you for reporting the problem. Could you try to log in and update the database?
Thanks for your quick reply, after logging in and clicking the update database button, my Rhino is not responding and ultimately crashes.
Hello. Would you be able to check the folder below and share a screenshot of the content?
C:\Users\USER\AppData\Roaming\One Click LCA
Note: USER = your user name.
Hi, yes. Please see the screenshot below.
Hi Mathew,
I have documented your feedback on the issues with the Rhino plugin. Would you be able to email support@oneclicklca.com, with the subject header “Rhino 7 issues” please? This would help us track this issue closely and respond when resolved.
Thank you.
