why LCA component does not apear in Grasshopeer?
Hi Hoda!
Once installed the plugin buttons will appear under ‘One Click LCA’.
If it is not showing up for you then I would recommend to reinstall the plugin, please only download it from Food4Rhino.
If that still does not work, please let us know what versions of your operating system and Rhino / Grasshopper you use so that we can investigate further.
Please check: Grasshopper Integration – One Click LCA Help Centre
Hi. Thank you for your help. I use Manual Install and when I was click on Rhino 6 Win install, it shows this error (Please see picture). It not work. My version is: Rhino 6, Grasshopper 2020. I do not know that what should I do.
Hi Hoda, thank you for providing your screenshots. I will have to discuss your case with our BIM developers; I will get back to you shortly.
Hi Hoda,
I have consulted with our BIM developers and they believe the errors are related to the version of Rhino. Would you be able to update it?
The following link provides more information on that: How can I update Rhino? | RhinoArtisan 6.0 Docs
If that does not work, could you let us know? We may have to investigate it a bit further then.
Hi.
Thanks for your help
I install Rhino 6.34 and Grasshopper 2021, and not working.
I can not install Rhino 7 or 8, because of my computer.
Hi Hoda,
Thanks for letting me know, I have asked our developers to look into this as the plugin was initially developed for Rhino 6 and Grasshopper so technically it should work. We will let you know when we know more.
