Hi guys. While working on a project using Grasshopper, I received a message after running the simulation saying “Stream from results was Null”. So, I was wondering why is this happening? In the image you can see the profiles, constructions and warning. Thanks
Hello Oswaldohb,
Can you please provide the GH script and the model for me to check what is the issue?
Hey!
As a follow-up, was this working before and it suddenly stopped? If it wasn’t working before, it might be due to license level limitations, as getting results within Grasshopper is an expert level license feature.
Hi, I have the same problem, with an expert license. How do I upload the file to you?
Hey Robin,
We are actively discussing with the plugin developers re this item.
On a side note, what Rhino version are you using? Have you updated to R8 already? If yes, you would also need to update our plugin to the latest version.
Yes, I have Rhino 8, and I reinstalled your plugin last week so it should be the latest version.
Ok, an update to my case. I was in contact with support and it turns out the material I have selected was the problem, the plugin works with some materials but not with others. This have something to do with the license, not sure how but hopefully they can get it fixed soon.
Correct, the plugin shows you all of our datasets, regardless of whether you can access them or not. To be sure the datasets showing are the right ones, make use of the plugin filters. That minimizes the chances of getting similar errors.
