Hi
I am NImesha. I was using One Click to analysis my revit model. Ended up with “No results Received”
Need help to get this sorted out ASAP.
Thanks
Hi
Thanks
Hi Nimesha! Loading your results in Revit is not included with our students licenses by default, I have enabled it for you to try for 14 days. I hope this helps with your assessment!
Thanks Steven,
We will start the integration ASAP. We were not able to start the work due to the disaster situation we had in Sri Lanka.
If further support is required, we will come back to you.
Once again thanks for the support.
Nimesh Sewwandi
Hi Steven
I need to get the result like the following in my research report with LEED certification. Revit Plug in result sheet does not give the format required.
Need your advice.
Hi Nimesh,
Please note that the results within the Revit plugin are intended for design optimization rather than formal certification. For LEED compliant results, you must use the One Click LCA cloud version.
Because we support over 140 different standards, full compliance capabilities are housed within our cloud calculation tools rather than the BIM plugin. The cloud platform allows for the exact life cycle stages, data granularity, and specific exports required to meet the rigorous standards of certifications like LEED.
