No results received - Revit (One Click LCA on Student License)
Hello, ive registered for a student license to use One Click LCA and using it with Revit for my master thesis. Whenever i proceed to gathering the results, a notification pops up saying no results from server. Is there a way to be able to use the plug in and get results in Revit?
Hi Sherainne,
It’s great to hear you’ll be using One Click LCA for your master’s thesis!
While our student licenses typically only support exporting data from Revit to One Click LCA for analysis, I’ve gone ahead and granted you a 14-day trial of the functionality. This should give you a good chance to explore that feature for your research.
Best of luck with your assessment!
Hi Steven, I currently have the same problem. I have a student license to use One Click LCA and am currently using it for PhD research. Can you grant me a trial of the functionality to get results? We plan to buy a full license later, once I’m more familiar with the LCA software, but for now, I want to test some things first.
Thanks in advance.
Aaron
Hi Aaron,
Great to hear you are using One Click LCA for your PhD research! I have given you temporary access to loading the results in BIM plugins, I would also recommend to check out the onboarding course. It’s free of charge and will help you get familiar with all of the software functionalities.
You can find this specific course at the following link: Construction LCA onboarding | One Click LCA Academy
Let me know if you have any questions,
Hi Steven,
I am experiencing the same issue as others while trying to use One Click LCA for my Master’s thesis. I already have my Revit model and would like to run an analysis on it, but I’m unable to log in. I keep receiving a message saying that my credentials do not match.
I also believe I may not have access to the BIM plugin, as I am using a student license.
Could you please provide me with a trial access so I can run the analysis and obtain the results for my research?
Thank you in advance.
Hi Jose,
I have given you access to run the results in Revit, good luck with your research!
Hi Steven,
I am currently using One Click LCA as part of my Master’s thesis, which focuses on integrating Life Cycle Assessment (LCA) into the early stages of architectural design. Unfortunately, I have been encountering the same issue reported by the other users, which is preventing me from accessing some of the Revit analysis features.
Having access to these functionalities would be extremely valuable for my research, as I need to evaluate and compare different workflow possibilities as part of the methodology I am developing. Would it be possible to grant me a trial access so I can test these features for my thesis?
I would really appreciate your help.
Helena
Hi Helena,
Nice to hear you are using One Click LCA for your master’s thesis! We would gladly help with this, so I have given your user account rights to load the results in Revit.
Best of luck with your research!
Hi Steven,
I am experiencing the same issue with my One Click LCA Student License and the Revit plugin. I am currently working on my undergraduate Civil Engineering thesis, using a BIM–LCA workflow to assess the embodied carbon of a reinforced-concrete building.
I can map the materials in Revit, but I am unable to receive the results back in the Revit plugin.
Would it be possible to enable temporary access to this functionality for my thesis research?
Thank you very much for your support.
