Revit plugin not loading results
Hi Louis, welcome to the One Click LCA Community! I have granted you access to load results in the Revit plugin for 14 days.
Hello Steven, hope you are doing well, I am facing the same error as i need the results for my research. Please help me out. Thanks :slight_smile: :smiley:
Hi Rudraksh,
Welcome to the One Click LCA community! I’ve just granted you access to load results directly within Revit.
For everyone else in this thread, I’d like to highlight our upcoming One Click LCA Bootcamps. These intensive sessions will take place from April 7th to 11th, providing comprehensive training on conducting Life Cycle Assessments (LCA) and effectively utilizing our software platform.
You can register for the bootcamps through our academy:
https://academy.oneclicklca.com/ (no separate account needed if you already have access to this community).
Hi Steven
I am very enthusiatically experimenting with OneclickLCA but am experiencing the same problem as most people here. I have been making myself familiar with the online version of OneclickLCA but would also like to use the plug-in in Revit. Is it possible to get acces to this feature while on the free trial..?
Thanks a lot!
I’m experiencing the same issue with error code 58252. I believe I have a student license.
Would it be possible for you to add the feature to my account as well? Thank you!
Hi Amber,
Access granted! You should now have access to the Revit plugin. Great to hear you are experimenting with One Click LCA and if you have any questions do not hesitate to reach out :slight_smile:
Hey Helin! I have granted you access for 14 days. Good luck with your assessments!
Hello!
I use one click LCA for student’s reasons and I would be gratefully appreciated if you would add for me an option to see the results through Revit plugin, right now I don’t have this option, but it could boost my workflow tremendously and also outcomes of my experience with one click LCA
Thank you!
Hi Timofei! I’ve given you access for 14 days :). I am always happy to hear what you think of One Click LCA!
Hello @Steven,
I have the student license, but results are only shown in the cloud, not in the Revit plugin, and I keep having error code 58252
Hi Islam! The option to load data in Revit is not normally included with student licenses. I can grant you 14 days of access to try it out, it should work now.
Hi @Steven,
I am having the having the same issue with my student licence and the Revit plug-in, is there anyway you can help.
regards,
Jason
Hey Jason, I’ve enabled the option to load results into the Revit plugin for you for the next 14 days. Let me know if anything else comes up!
Hi @Steven
I believe I’m having a similar issue. I am trying out the business free-trail and getting the error ā€œplease repair your installation error code 58252ā€. This occurs when I enter the results panel. I have reinstalled the revit plugin with no luck
Thank you!
Brittney
Hey Brittney, just letting you know you now have access to load the results in Revit. By the way, the next update will make that error message much clearer – you’ll actually know what’s going on!
Hi! i am also currently experiencing this error(error 58252) when i try to open the results in revit. I already have a student license and I would like to ask how I can fix this error? Thanks
Hi Lawrence,
Are you using the latest version of the One Click LCA plugin for Autodesk Revit? The current version should provide a specific reason for results not loading, rather than a generic error. Could you please let me know which versions of Revit and the plugin you’re using?
The error you’re seeing typically indicates a licensing issue preventing the results from loading, which isn’t usually included with student licenses. I’ve gone ahead and given you 14 days of access to this function.
Hi Fajar,
I’ve given you 14 days access to load the results in the Revit plugin.
