Hello! Posting a list of things I’ve noticed with the software that I would love to get resolved:
- Unable to scroll all the way to the far right - solution: implement freeze pane so material item column is locked while scrolling to the right
- Some EPDs are incorrectly tagged on 1C
- Search feature for EPD look up is dependent on particular phrasing. ie. looking up NRMCA pacific southwest EPDs, have to type “pacific southwest” but looking up “NRMCA” doesn’t work
- Sorting function not working
- Incorrect values pulled from selected EPD at times
- Most up to date EPDs not at the top of search feature.
- Gerdau Wide Flange EPD reports 0 in the A1-A3 emissions
- Units showing incorrectly when uploading excel file onto One Click
- Unit issues with cubic yards and cubic feet for concrete
Hi Priyal,
welcome to the community and thank you for your valuable feedback! I am sorry to hear that you are experiencing some issues.
Thank you for your input concerning this. I forwarded this to our product developers for consideration. Please let me know if you would want to receive an email if there are changes with regard to this.
Please see below
Using the LEED (US) tool, I received >8000 results when searching for “NRMCA”. Which tool did you use?
Please see below
A common reason for the values used in the OCL calculation not matching the ones in the EPD is Materials Manufacturing Localisation. If that doesn’t explain what you experienced – please see below
Thank you for sharing your opinion about this. Our Software developers are currently working on filters to sort data according to its publication date and expiry date. Please let me know if you want to receive an email as soon as this is implemented.
Please see below
There is a check-box on the import process’s settings page, which converts all inputs to the metric unit system if ticked. Does this issue also occur if the box is unticked?
Please see below
I suggest discussing points 2, 4, 5, 7 and 9 in our meeting next week, because I’d kindly ask you to specify a bit more about what exactly you are experiencing/which EPDs are affected.
