Generic data are either country specific or global but using the planetary global software and I tried to read the data set of some generic material data from my country,I see it displaying those values under environmental profiles as ‘without localisation’ this is kind of confusing to me,pls can somebody clarify.
Hi Sunday!
All generic data in One Click LCA is automatically localized based on your project’s country setting.
The “without localization” label you see on a generic material’s datacard refers to its base environmental profile—before project-specific adjustments like the local electricity grid mix or transportation are applied. This datacard serves as a standardized reference.
The final, fully localized emissions are calculated and visible directly within your project’s results. By reviewing the calculated impacts for the material in your project, you will see the final, localized values.
In short, the datacard shows the generic starting point, while your project calculation shows the final, localized result.
