Error 67655 using revit
I look after the software issue with the company I am with, one colleague is getting an error 67655 when using the program in revit, I have uninstalled and reinstalled
Hello Damian, thank you for joining the forum and for raising this issue.
Please uninstall and reinstall the latest version of the Revit Plugin 4.0.9 from Autodesk App Store.
You can follow these instructions:
Close Autodesk Revit.
Uninstall the plugin
Open Autodesk Revit to ensure that this is fully uninstalled.
Install the plugin again.
Restart your PC.
Open Autodesk Revit again and try to open the plugin
If you are using linked model, you can try to unlink them and open each model separately to troubleshoot where the problem is.
In case none of these solutions work (you can send us screenshots), please email us your Revit model to support@oneclicklca.com
Thanks, will give that a go
