I am having trouble with the measurement units when entering the design’s annual energy and water consumption.
For instance, in a hot, dry region, I may utilize the baseline numbers listed by the IFC (2015) for educational facilities housing up to 1,500 students.
Energy: 72 kWh/m2 per year
Water: 50 liters per person per day
Would entering the necessary data in the OneClick gateway require me to carry out actions based on my design?
Energy: Multiply the area of my building by my base consumption.
Water: Take the product of my base consumption and the fictitious population times 365 days.
The reason for this is that, the OneClick site displays as the unit of measurement:
Energy: kWh annually
Water: m3 annually
Your understanding of the input method is correct. We enter the total annual energy and water consumption values, after which your ‘calculation period’ set will multiply the quantities/emissions by that number.
Your energy consumption depends indeed on the area (GIFA/GFA) of your building and again needs to be annual consumption so 72*m2 GIFA.
Your water consumption based on your data would be 27375 m3 annually and roughly 290t CO2e for 60 years.
(example used with UK carbon factors)
I hope this is clear and let me know if you have any other questions!
