Ecoinvent versions
If you have a design and we epd calculation using one version of ecoinvent is there an easy way of updating the calculation to use the newer version of ecoinvent for all data points?
Hi!
Thanks for your question.
The best way to do this is to use the excel import feature, essentially reimporting your LCA model to a new design and mapping the resources to the latest version of ecoinvent.
We are currently working on a solution that would make switching between ecoinvent versions much easier so watch this space :wink:
Kind regards,
