Ecoinvent 3.10 and Epd's
I have read that Ecoinvent has been updated to 3.10.
When creating an epd and searching for datapoints some are only available in 3.8. When creating an EPD can you mix ecoinvent version datapoints and would this be acceptable to the verifier?
Hi David,
We’ve updated our system to include ecoinvent 3.10.1. The initial release (3.10) had a bug that inflated emissions, so Ecoinvent quickly moved to 3.10.1. This latest version is available in the “EPD Generator for EPD Hub v3” tool, which you have access to with your current license. The older ecoinvent 3.8 version is available in the “EPD Generator for EPD Hub v2” tool.
Our EPD team has already migrated your projects and created copies using ecoinvent 3.10.1. It’s generally best practice to avoid mixing different ecoinvent versions within a single project.
I have asked our EPD team to reach out as well, in case you need assistance.
