Carbon Design 3D tool - changing the shape of the building
Is there some way you can change the shape of the building in Carbon Design 3D tool?
Hi Elisa,
Thanks for reaching out and welcome to our Community!
Thanks for your question and welcome to our Community!
The shape efficiency factor adjusts the factor between the lengths of the walls for the longer side of the building. The measurements are calculated according to the fixed 1.1 ratio. Adjusting the factor also increases the area of internal walls, so it is not recommended to change the factor without manually adjusting the area of internal walls.
Moreover, you can edit manually any building structure and input how much you expect that element to be present in the building.
You can read more in our Help Centre article and in our Academy minicourse .
