What's new in One Click LCA in January 2026
What’s new in One Click LCA in January 2026
Update Highlights
  • Find relevant data faster with four new pre-filtered search tabs for Local and Regional EPDs and Generics.
  • Prevent accidental changes and ensure data integrity by locking individual resources or entire designs in the new data input interface.
  • Streamline compliance reporting for Nordic and North American projects with updated support for NS3720, BR25, and LEED v5 Metric.
  • Iterate designs safely by merging Carbon Designer 3D models into existing projects without overwriting current data.
  • Achieve greater modeling precision using 7000+ new datasets and enhanced concrete EPD characteristics.
Platform & software updates
Streamlined resource search
The new data input search now includes four pre-filtered tabs to help users find the most relevant data faster. These tabs replicate the preferred hierarchy from the classic interface:
  • Local generics
  • Local EPDs
  • Regional generics
  • Regional EPDs
The existing fully customizable filter tab remains available as the default view.
Enhanced data control with locking features
Users can now lock individual resources or entire designs directly within the new data input interface.
  • Resource Locking: Secure specific rows to prevent editing while keeping the rest of the project flexible.
  • Design Locking: Set whole designs to read-only mode, ensuring finalized data remains unchanged during review or after completion.
Standardizing the new data input interface
The new data input interface is now the default view for Business and Designer licenses (excluding Japan). This transition brings improved navigation, faster grouping, and modern workflow tools to a wider user base.
Building & Infrastructure LCA updates
Faster compliance with LEED v5 North America Metric
The LEED v5 North American tool is now available in metric units. Users can perform the same robust assessments and generate compliant reports using metric inputs.
Enhanced workflows in Carbon Designer 3D
  • Flexible Design Merging: Data from a Carbon Designer 3D design can now be merged into one or multiple project designs at once without overwriting pre-existing data. This allows for safer iteration and easier integration of early-stage models.
  • Norway Region Update: The Norway 2019 region has been updated with ‘lavkarbon’ default data, aligning it with Carbon Designer 2D for consistent low-carbon baselines.
  • UK Region Update: A new RICS v2 aligned region has been added, matching the latest RICS manual guidance for baseline material specifications.
Private data for RICS v2 deconstruction
Users can now create private data specifically for the deconstruction/demolition (C1) stage in RICS 2nd edition projects, allowing for precise definition of both decarbonized and non-decarbonized impacts.
Product LCA & EPDs updates
Streamlined NMD compliance with updated Set A2 tool
The NMD Set A2 tool has been overhauled to ensure full alignment with the latest Dutch market requirements:
  • Accurate Reporting: Calculation logic has been updated to provide correct MKI values.
  • Streamlined Results: Exports now focus strictly on Set A2 data, removing unnecessary tables.
  • Compliant Formats: Results are generated in the correct Excel format required for NMD submission.
Streamlined workflows for INIES & PEP
The EPD Generator for Ecoinvent 3.10 (INIES & PEP) is now fully compatible with the new user interface, offering a faster and more modern experience for French market declarations.
Direct data list management
Users can now add Ecoinvent resources to their data lists directly from the new query interface, removing the need to switch back to the company account view.
Enhanced concrete and coating data
Concrete EPDs: New characteristics for strength evaluation days (365 days) and compressive strength class (C10/12) are now available.
Local Updates
Automated, localized reporting for Nordic certifications
Norway: NS3720
The NS3720 tool is now fully compatible with the new user interface, featuring:
  • “Operational transport” query support.
  • Streamlined workflow for Norwegian compliance.
Denmark: Bygningsreglementet 2025 (BR25)
The calculation tool for BR25 is now available in the new interface.
  • Enhanced Service Life Logic: The tool now prioritizes project-specific service life scenarios over default resource values, ensuring more accurate calculations for technical service life.
France: Smoother RE2020 data imports
The “Import data from RSET/RSEE” feature in the RE2020 tool has been refined for reliability:
  • Accuracy: Climate zones are now auto-imported from XML for precise threshold calculations.
  • Guidance: Missing fields are clearly highlighted with direct links for completion.
  • Consistency: Auto-consumption rates for local electricity are now systematically checked and imported.
Greater modeling precision with 7000+ new datasets
The database now includes 7171 new datasets, including the updated Baubook database. These additions enhance regional accuracy and material representation for both construction and manufacturing
Expanded 187 coverage with new generics
We have added a massive tranche of generic datasets specifically targeting MEP (Mechanical, Electrical, and Plumbing) and Infrastructure projects. This fills a critical gap for early-stage modeling where verified EPDs are rare.
Breakdown of new resources:
Power Regulation & Quality:
  • Automatic Voltage Regulators (AVR): 15 new types (PCB-mounted to high-capacity industrial 500 kVA).
  • UPS Systems: 8 new units (1 kVA to 40 kVA modular towers).
  • Reactive Compensation: 8 new components (Capacitors and harmonic modules).
  • Power Supplies: 5 new units (DIN-rail DC supplies, DC-DC converters).
Circuit Protection & Safety:
  • Arc Fault Interrupters (AFCI): 10 new types (Residential, commercial, and DIN-rail).
  • Residual Current Monitors (RCM): 10 new types (EV charging, data centers, portable)
  • Surge Protection (SPD): 10 new types (PV string, Type 1/2/3, Telecom).
Cabling & Management:
  • Cable Glands: 32 new types (Polyamide, Brass, Armoured/Unarmoured)
  • Installation Cables: 9 new types (PVC and LSZH insulation).
  • Tension Clamps: 15 new types (Aluminium alloy, Polyamide, Dead-end wedge).
Control & Automation:
  • Switches: 19 new types (SPST, SPDT, Load break switches up to 36 kV).
  • Relays: 9 new numeric protection relays (Feeder, Motor, Generator, Differential).
  • PLCs & Interfaces: 9 new units (DIN-rail PLCs, I/O modules, HMI panels).
  • Motor Control: 3 new units (Soft starters, VFDs).
Monitoring:
  • Energy Meters: 9 new types (Smart meters, DIN-rail, Revenue grade).
Demolition:
  • New C1 Scenarios: Concrete demolition and Asphalt pavement removal (milling).
