Secondary material in the product and Ecoinvent data
I am creating an EPD where all my raw materials datapoints are (unfortunately) generic data. Still, in the results it is shown some values in “Secondary material”.
Shouldn’t it be zero if in fact my product contains no recycled material? And if it should be zero, would it be possible to make the software so that it wouldn’t take the secondary material from generic data to the results?
What about for example packaging materials. If those are made for example from recycled plastic, should I take those account when calculating secondary material use? I think I shouldn’t…?
Hi Elisa,
Good question! Generally speaking, yes, but not always. Use of secondary material doesn’t necessarily equal recycled content, although it is a good indication of it. It’s possible that secondary material (scrap/waste), is used in the production of a material. However, that doesn’t mean that the final material has any, or an equivalent amount of, recycled content in it.
For example, “steel electric” has secondary material use of ~1.13kg/kg, but it’s not possible that it has 113% recycled content, i.e., greater than 100%. For some datapoints this occurs due to losses being accounted for.
Having said that, the use of secondary materials indicator is often the closest source of information we have to determine recycled content of a generic dataset. So, you can use this to help you evaluate if a dataset is the most representative choice for your LCA model.
And you are correct that packaging should not be included. Secondary material, inputs (%) as shown in the Environmental Data Summary table of EPD Hub EPDs is calculated based on the declared unit of the product only.
Thanks for posting,
Hi! Thank you Graham :slight_smile:
What about the secondary material outputs (%). How does the software calculate those? What it includes there? Apparently also a product that is used as energy? And only from the declared product, not packaging materials?
Best reagards, Elisa
Hi Elisa,
The secondary material outputs % is calculated using the below formula:
((C3 mass of components for reuse + materials for recycling + materials for energy recovery)
divided by
(Mass of the declared unit + A5 installation resources mass))
multiplied by
100
For example:
  • Declared unit: 1m2 of product with a mass of 5kg
  • A5 installation resources: 0,1kg of adhesive
  • C3 scenario: 70% of the product is recycled, the remaining 30% is landfilled, and 100% of the adhesive is incinerated without energy recovery
Formula:
((5kg * 70%) / (5kg + 0,1kg)) * 100 =
(3,5kg / 5,1kg) * 100 =
68,63%
I hope this helps,
Hi Graham
Thank you, this helps. Although I still get a slightly different result when I calculate with the formula you provided compared to what is printed in the EPD report.
Elisa
Hi Elisa,
Let’s look into this together. Please reach out to us in support so we can double-check your result.
Thanks,
