How to make bulk changes? - Group Edit!
Do you want to set the wastage-% to 0 for all materials or change the service life of the five materials you just added to 25 years instead of the default 30?
Instead of changing each data row in your building materials query, you can group edit materials:
  1. While left-clicking, drag your mouse over the materials which you want to adjust. This should highlight them in green.
  2. Right-click on the area that is now highlighted in green. This opens several options (including copying and moving data).
  3. Click on the option “Goup edit”. This opens a pop-up window.
  4. Click on “click to edit” next to the aspect that you want to change (e.g. service life).
  5. Enter the new value that you want to see for all the selected materials.
  6. Click on update - and you’re done!
Here are some screenshots describing the workflow.
