Hi
Found a product EPD on NBS Source that I cannot locate on OneClick:
Gypsum panel by BEAM (Ekobat Batec Ask) - ref: EPD10669.
How do I confirm if this is a valid and up to date certificate?
Thanks
Hi
Thanks
Hi Bunmi! This EPD is available in the One Click LCA database, please search with EPD10669 and you will get a few options to choose from. The EPD is valid till 19.11.2026
Hi Hetal - thanks for the quick response!
still cant find it, is this to do with the tool I am using: Carbon AssessmentGLA/RICS/Green Mark (+2)?
Yes, indeed. It is available in our LEED, North America Tools.
If you would like to know more about the tool please write to us at support@oneclicklca.com
OK - thanks, will look into this.
What is the best way (tool) to ensure the widest possible range of EPDs are being searched?
Our tools are designed according to the calculation requirements of different certifications and EPDs available align with the requirements of those certifications. For example, your tool has EPDs with CML indicators whereas the LEED, NA tool has EPDs with TRACI indicators. So your choice of tool will depend on what certification you are calculating for
Understood - Thanks Hetal!
