Change resource allocation in building material query
Dear team,
I’m working on reclassifying resources in OneClick LCA and need a more efficient way to edit multiple rows at once.
When I try to change a resource’s category (e.g., from “External Wall” to “Load-Bearing Structure”), the right-click “move” function only applies to a single row, even when I have multiple rows selected. Given the large number of resources, doing this one by one is very time-consuming.
Is there a way to batch-edit or bulk-move multiple rows simultaneously?
Thank you
hello @Bo_Pan , you pick many rows from left-side checkboxes and then select “Move” at the top (see image below). This enables bulk move.
