Update Highlights
- Design low-carbon buildings earlier using structural logic, generative design, and local data — in Carbon Designer 3D
- Catch errors before third-party review by benchmarking data quality — with EPD Plausibility Checker
- Ensure compliance and protect sensitive project data using new address and privacy settings
- Model regional impacts more accurately with new LCI data from ProBas, Carbon Minds, and NMD
- Cover more materials and product types with 3,000+ new datasets now available in the database
Early-phase design update
Generate credible early-phase design alternatives automatically using basic project inputs like floor area, height, site boundaries, and constraints. Eliminate the need to build manual models just to compare structural systems.
- Evaluate carbon impacts of multiple design options in minutes
- Make earlier, better-informed structural decisions with minimal inputs
- Cut time to analysis and unlock carbon savings from the start of the project
Generative design is available with the One Click LCA Power Pack during July.
Get more realistic early-stage structural quantities for better design decisions
Structural material estimates now reflect typical design practices thanks to a new efficiency factor based on frame type. Whether using steel, timber, or precast concrete, quantity calculations for beams, columns, and shear walls are now automatically adjusted to improve accuracy.
Align early estimates more closely with likely structural designs
Generate more credible and defensible carbon results at concept stage
Reduce the need for manual adjustments or placeholder assumptions
Improve early design accuracy with updated stair and elevator logic
Staircase layouts now better reflect typical floor-to-floor configurations and landing requirements in multi-story buildings. Elevator counts are dynamically estimated using staircase-to-elevator ratios that vary by building type.
- Aligns early-stage massing with common code-based assumptions
- Improves realism in vertical circulation estimates
- Supports more credible early-phase carbon and quantity outputs
These refinements increase consistency between automated models and real-world design expectations. These updates are expected to be introduced to the One Click LCA platform during July.
Model Eastern European projects with region-specific data and assemblies
A new Eastern Europe region is now available, including 89 ready-to-use construction assemblies for foundations, frames, walls, slabs, and finishes. These reflect local construction practices in countries like Poland, Romania, Greece, and Estonia.
- Supports accurate early-stage modeling with locally relevant assumptions
- Aligns with EN 15804+A1-compliant LCA workflows
- Reduces setup time with pre-assembled elements tailored to regional norms
Automatically available for all users with an active Carbon Designer 3D license.
Software & Platform updates
Improve whole-life carbon accuracy for MEP systems with support for B2 and B3 stages
The MEP carbon tool now includes maintenance (B2) and repair (B3) stages, enabling more complete assessments of HVAC, electrical, plumbing, and other building services systems.
- Capture impacts from maintenance parts, energy, and water via a dedicated input
- Model repair emissions as a share of A1–A3 values using familiar workflows
- Ensure compliance with EN 15978 and other whole-life carbon standards
- Supports both metric and imperial units for global project alignment
Enhances LCA scope for more reliable operational-phase impact modeling.
Save time and reduce errors with improved data import workflow
The import interface now retains Country, Data Type, and EPD Program filters across rows, streamlining manual mapping and reducing repetitive selections.
- Improves efficiency and minimizes mapping errors
- Enhances precision for low-volume entries with updated quantity display
- Ensures trial users and students access the latest import tools by default
Delivers a smoother, more accurate experience across all user types and workflows.
Find materials faster with improved project-country filtering
Material search now prioritizes your selected project country and displays relevant datasets more intuitively.
- Project country appears at the top of the Country filter list for quicker access
- Generic datasets now show alongside national ones, reflecting default localization
- Speeds up early-stage assessments by simplifying dataset selection
Delivers a smoother, more efficient experience when sourcing materials for location-specific modeling.
Improve result reliability and team coordination with updated Plausibility Checker
The Plausibility Checker now supports collaborative validation and is no longer in BETA. A new “Validated” toggle lets users confirm flagged entries and exclude them from plausibility scoring.
- Shared validations ensure consistency across project team members
- Reduces rework and improves trust in model outputs
- Enhances transparency and robustness of plausibility scoring
Strengthens quality control across complex, multi-user LCA workflows.
Improve model accuracy and meet regional requirements with geolocated projects
Providing a project address is now required when creating new building projects. This ensures geographic context is captured from the start — improving the precision, relevance, and regulatory readiness of your carbon assessments.
- Automatically applies local climate zones, regional carbon factors, and environmental defaults
- Enables more accurate baseline comparisons and clearer result interpretation
- Supports filtering and segmentation in analytics dashboards and reporting tools
- Ensures compliance with location-based frameworks such as EU Level(s) and national LCA standards
By capturing location data upfront, this change enhances model fidelity and aligns your workflows with the direction of LCA regulation — where regional specificity is rapidly becoming mandatory.
Classified project setting for sensitive work
Projects can now be marked classified, hiding their names from shared analytics, dashboards, and usage summaries. This helps protect NDA-bound, competitive, or internal R&D work while still allowing participation in aggregated platform insights.
Projects can also be marked as classified, which hides project names from shared usage insights, dashboards, and organizational summaries. This is essential for NDA-bound projects, confidential R&D, or competitive tenders. Existing projects are treated as classified by default.
A new benchmarking feature flags EPD results that fall outside typical performance ranges using reference data from the One Click LCA database. This helps catch input or modeling errors earlier, improving quality and reducing verification back-and-forth.
The plausibility checker will be made available during July.
Expanded regional datasets improve regulatory alignment and modeling accuracy
- ProBas (Germany): 11,500+ license-free datasets across 81 countries for feasibility, compliance, and early-stage modeling.
- Carbon Minds: Adds region-specific chemical and plastic LCI data for 1,500+ materials across 200+ regions. Licensed separately.
- NMD Process (Netherlands): Now supported in Dutch EPD tools with versions based on both Ecoinvent 3.6 and 3.9.1.
Aligning with EPD Hub’s PCR 1.2 updates
EPD Hub-compatible tools now calculate the share of specific data automatically, include bibliographic fields, and support “worst-case” grouping. Grouping is also now possible in E2E tools.
Sectional mass input removed for consistency
Sectional mass has been removed from input forms and is now validated on the result page, ensuring more reliable mass logic across tools.
Greater control and precision with improved IFC Viewer and import options
The IFC Viewer has been enhanced to give users greater transparency and selectivity when importing model data into One Click LCA.
- View the complete list of IFC properties for each building element
- Select which properties to include or exclude from import
This feature provides more precise control over incoming data, reducing the inclusion of irrelevant attributes and minimizing post-import cleanup. It also supports more accurate LCA modeling by ensuring only pertinent fields are used for quantity take-off and material definition.
More accurate data exports with updated DesignBuilder plugin (v7.3.1)
The latest update to the DesignBuilder plugin for version 7.3.1 improves the completeness and formatting of exported Bill of Materials for import into One Click LCA.
Key enhancements include:
- Direct export to Excel in the One Click LCA standard import format
- Inclusion of photovoltaic (PV) panels using the BUILDINGTECH classification
- Export of materials from component blocks and local shading devices
- Support for both “Simple” and “Material layers” glazing definitions
- Improved handling of internal elements under the 1-Inner zone geometry setting
These updates reduce the need for manual edits post-export and ensure more comprehensive material data is captured for early-stage or detailed LCA modeling.
Faster, clearer documentation for Finnish and Japanese users
Updated Word report formats are now available for the Finnish Low Carbon tool and the Japan Life Cycle Carbon tool. The Japanese version now includes bilingual support.
Finnish compliance automation
The Finnish tool now includes a compliant XLSX export (rakennustuoteluettelo) with carbon results and TALO2000 codes, ready for submission.
Updated Swedish tools for Klimatdeklaration, Miljöbyggnad 4, and NollCO2
National defaults (wastage, transport), new GWP reporting formats, and a 25% GWP top-up for lower-quality data now apply.
Improved biogenic carbon modeling for Green Star NZ
The Green Star NZ tool now applies biogenic carbon logic based on end-of-life scenario selection — better aligning with EN15804+A2.
Expanded QNG energy input support
The QNG tool now includes B6.2 and B6.3 inputs (elevator and unregulated electricity) in the reference values query.
ProBas LCI database now integrated in EPD tools
The ProBas life-cycle inventory database from the German Environment Agency is now fully integrated. It includes over 11,500 license-free datasets across 81 countries — more than 5,000 of which are German-specific — spanning energy, transport, chemicals, metals, agriculture, and more. This supports early-stage modeling, public-sector work, and German regulatory alignment.
Carbon Minds database expands chemical sector coverage
Carbon Minds data is now supported in One Click LCA’s EPD tools, adding over 1,500 region-specific datasets for chemicals, plastics, adhesives, and coatings across more than 200 regional supply chains. This supports accurate modeling of highly engineered and MEP-intensive products. Note: licensed separately and available shortly after release.
NMD process database added for Dutch EPD compliance
The Dutch National Environmental Database (NMD) process datasets are now integrated in One Click LCA’s Dutch EPD tools, with versions based on both Ecoinvent 3.6 and 3.9.1. This ensures compatibility with Milieuprestatie gebouwen (MPG) methodology.
Strengthening coverage with 2,868 new industry datasets
Expands modeling across materials, production methods, and industrial sectors — especially construction, infrastructure, and manufacturing. New datasets support more detailed, accurate, and representative life-cycle modeling.
New generic datasets to support early-phase modeling
315 new generic datasets cover electronics (e.g. LEDs, connectors), refrigerants, forestry operations, and average materials across Europe.
