EPD | Warning | Datapoint missing information
I am performing a Whole-Building Life-Cycle Assessment for an office building in Portugal according to the LEED v4.1 BD+C MR credit Building Life-cycle Impact Reduction (Option 2) requirements.
While mapping the construction materials [1], I noticed the following warning:
Can you provide a detailed explanation of this non-conformity so I can report it to the product manufacturer?
Thanks in advance for your insights.
[1] EPD - https://daphabitat.pt/assets/Uploads/dap/pdfs/93ac60ed32/DAP-017-2022_PT-Artebel.pdf (PT version)
Hi João!
The issue with this resource is as the warning says, the missing mass of the declared unit.
The manufacturer has decided to record the emissions of their product per 1 square meters. However, the mass information they reported, is 1300 KG / m3. From the document, we unfortunately cannot find out the thickness of the product and thus we do not know what 1 m2 of their product weighs.
If we do not know the weight of the product, we cannot calculate the transportation or the amount of product that will be recycled and therefore the resource is disabled.
If the manufacturer can provide the mass per square meter (e.g. mm, or kg per square meter) then we will be able to include the product.
As per the product datasheet [1]: 560x190x110mm AND 7kg/unit.
Thanks again for your assistance.
[1] www.artebel.pt/storage/uploads/base/ficheiros/declaracao_desempenho_bloco_freebloco.pdf (PT version)
Hi João, I will discuss this with our data team and let you know if this is sufficient.
Hi João, as the EPD its functional unit is per m2, we would need to understand if mortar or similar materials are included, which would change the quantity of blocks per m2. Would you be able to confirm this with the manufacturer?
According to the system boundary description, and as per manufacturer feedback, mortar or similar materials are not included: “Transportation to the site or the distributor, as well as its application on-site, are outside the scope of this study.” (EPD, section 2.1.2).
The same occurs with the following ARTEBEL products:
  1. Concrete block made of expanded clay aggregates:
    a) EPD;
    b) Datasheet:
    i) TERMISOBEL:
    i.i. BTI.5020 (500x190x200mm, 16 kg per unit);
    i.ii. BTI.5025 (500x190x250mm, 18 kg per unit).
    ii) TÉRMICOproETICS:
    ii.i. BTE.5015 (I) (500x190x150mm, 10 kg per unit);
    ii.ii. BTE.5020 (II) (500x190x200mm, 12 kg per unit);
    ii.iii. BTE.5025 (II) (500x190x250mm, 14 kg per unit);
    ii.iv. BTE.5030 (II) (500x190x300mm, 16 kg per unit).
  2. Thermal masonry units:
    a) EPD;
    b) Datasheet:
    i) MEGATÉRMICO:
    i.i. BMT.3538 (350x190x380mm, 22 kg per unit);
    ii) TERMOACÚSTICO:
    ii.i. BTA.4031 (400x190x315mm, 20 kg per unit).
  3. Acoustic masonry units:
    a) EPD;
    b) Datasheet:
    i) ISOARGILA:
    i.i. ISO.4015 (I) (400x190x150mm, 10 kg per unit);
    i.ii. ISO.4020 (II) (400x190x200mm, 14 kg per unit);
    i.iii. ISO.4025 (III) (400x190x250mm, 17 kg per unit);
    i.iv. ISO.4030 (IV) (400x190x300mm, 21 kg per unit).
Looking forward to hearing back from you.
Hi João, thanks for that. I have created a ticket to our data team who will ensure these resources can be used. We will let you know once they are available!
