January 2024 - 46 New Generic Resources
During January, we have added 46 generic resources, this number may increase during the rest of the month which means this article will be updated. Let us know if you have any questions related to these new generic options!
You can find the resources in the software tools with the written names below.
Note: Not all calculation tools allow for the use of generic resources.Where their use is not allowed these resources will not show up.
Floor tile - 1 new
Marble floor tile, 18 mm , 48.6 kg/m2, (One Click LCA)
Aluminium framed windows and patio doors - 12 new
Aluminium frame window double-glazed, operable(tilt and turn), 50% recycled aluminium, 1.48 m x 2.18 m, 25.3 kg/m2, (One Click LCA)
Aluminium frame window double glazed, non-operable, 50% recycled aluminium, 1.48 m x 2.18 m, 22.3 kg/m2, (One Click LCA)
Aluminium frame window triple glazed, operable(tilt and turn), 50% recycled aluminium, 1.48 m x 2.18 m, 32.6 kg/m2, (One Click LCA)
Aluminium frame window triple glazed, non-operable, 50% recycled aluminium, 1.48 m x 2.18 m, 30.7 kg/m2, (One Click LCA)
Aluminium frame window double-glazed, operable(tilt and turn), 0% recycled aluminium, 1.48 m x 2.18 m, 25.3 kg/m2, (One Click LCA)
Aluminium frame window double glazed, non-operable, 0% recycled aluminium, 1.48 m x 2.18 m, 22.3 kg/m2, (One Click LCA)
Aluminium frame window triple glazed, operable(tilt and turn), 0% recycled aluminium, 1.48 m x 2.18 m, 32.6 kg/m2, (One Click LCA)
Aluminium frame window triple glazed, non-operable, 0% recycled aluminium, 1.48 m x 2.18 m, 30.7 kg/m2, (One Click LCA)
Aluminium frame sliding patio door, double-glazed, 40% recycled aluminium, 3 m x 2.18 m, 43.77 kg/m2, (One Click LCA)
Aluminium frame sliding patio door, triple glazed, 40% recycled aluminium, 3 m x 2.18 m, 51.76 kg/m2, (One Click LCA)
Aluminium frame sliding patio door, double-glazed, 0% recycled aluminium, 3 m x 2.18 m, 43.77 kg/m2, (One Click LCA)
Aluminium frame sliding patio door, triple glazed, 0% recycled aluminium, 3 m x 2.18 m, 51.76 kg/m2, (One Click LCA)
Autoclaved aerated concrete units - 9 new
Autoclaved aerated concrete solid blocks, 4x8x16 inch, 600 kg/m3, 5.03 kg/unit, (One Click LCA)
Autoclaved aerated concrete solid blocks, 6x8x16 inch, 600 kg/m3, 7.55 kg/unit, (One Click LCA)
Autoclaved aerated concrete solid blocks, 8x8x16 inch, 600 kg/m3, 10.06 kg/unit, (One Click LCA)
Autoclaved aerated concrete solid blocks, 4x8x12 inch, 600 kg/m3, 3.77 kg/unit, (One Click LCA)
Autoclaved aerated concrete solid blocks, 6x8x12 inch, 600 kg/m3, 5.66 kg/unit , (One Click LCA)
Autoclaved aerated concrete solid blocks, 8x8x12 inch, 600 kg/m3, 7.55 kg/unit, (One Click LCA)
Autoclaved aerated concrete solid blocks, 4x3x9 inch, 600 kg/m3, 1.06 kg/unit, (One Click LCA)
Autoclaved aerated concrete solid blocks, 4x6x9 inch, 600 kg/m3, 2.12 kg/unit, (One Click LCA)
Autoclaved aerated concrete solid blocks, 4x6x12 inch, 600 kg/m3, 2.83 kg/unit, (One Click LCA)
Organic insulation - 2 new
Wheat straw bale insulation, L=0.048 W/mK, R=4.58 Wm2/K, 220 mm, 24.4 kg/m2, 111 kg/m3, (One Click LCA)
Wheat straw bale insulation, L=0.048 W/mK, R=9.58 Wm2/K, 460 mm, 51 kg/m2, 104 kg/m3, (One Click LCA)
Copper products - 6 new
Copper sheet, 1 mm, 8.96 kg/m2, 8960 kg/m3, 0% recycled, (One Click LCA)
Copper sheet, 1 mm, 8.96 kg/m2, 8960 kg/m3, 50% recycled, (One Click LCA)
Copper sheet, 1 mm, 8.96 kg/m2, 8960 kg/m3, 100% recycled, (One Click LCA)
Copper wire rod, 8960 kg/m3, 0% recycled, (One Click LCA)
Copper wire rod, 8960 kg/m3, 50% recycled, (One Click LCA)
Copper wire rod, 8960 kg/m3, 100% recycled, (One Click LCA)
Bronze products - 9 new
Tin bronze (phosphor bronze) sheet, 1 mm, 8.88 kg/m2, 8800 kg/m3, 50% recycled copper, (One Click LCA)
Tin bronze (phosphor bronze) wire rod, 8800 kg/m3, 50% recycled copper, (One Click LCA)
Tin bronze (phosphor bronze) cast part, 50% recycled copper, (One Click LCA)
Bearing bronze sheet, 1 mm, 8.91 kg/m2, 8910 kg/m3, 50% recycled copper, (One Click LCA)
Bearing bronze wire rod, 8910 kg/m3, 50% recycled copper, (One Click LCA)
Bearing bronze cast part, 8910 kg/m3, 50% recycled copper, (One Click LCA)
Aluminium bronze sheet, 1 mm, 7.45 kg/m2, 7450 kg/m3, 50% recycled copper, 1 mm, 7.45 kg/m2, 7450 kg/m3, 50% recycled copper, (One Click LCA)
Aluminium bronze wire rod, 7450 kg/m3, 50% recycled copper, (One Click LCA)
Aluminium bronze cast part, 7450 kg/m3, 50% recycled copper, (One Click LCA)
Gypsum products - 2 new
Natural gypsum powder, (One Click LCA)
Gypsum plaster, from 100% natural gypsum, in powder form, (One Click LCA)
Alternative concrete binders - 5 new
Basalt powder, (One Click LCA)
Limestone powder, (One Click LCA)
Silica sand, (One Click LCA)
Volcanic ash, pulverized, from fallout collection, bulk density 1703 kg/m3, (One Click LCA)
Volcanic ash, pulverized, mined, bulk density 1703 kg/m3, (One Click LCA)
