Introducing Materials Compass — find, compare, & choose low-carbon construction materials
Do you need to find, compare, and choose low-carbon construction materials with ease? Discover sustainable options from the largest LCA database, featuring over 250,000 low-carbon materials. Make informed choices to cut carbon emissions and achieve your sustainability goals. The Materials Compass from One Click LCA is designed to help construction professionals cut carbon in their projects & achieve sustainability goals by finding, comparing, and choosing the most sustainable building materials.
Key features of Materials Compass:
  • Extensive database: Access over 250,000 materials from the world’s largest construction LCA database.
  • Easy comparison: Compare materials based on sustainability criteria to find the best options for your projects.
  • Custom lists: Create personalized lists of materials for your ongoing projects.
  • Bookmarks: Bookmark materials to quickly find and use them when needed.
  • Share and export: Save time by sharing materials via email and exporting them to your One Click LCA projects seamlessly.
Learn more about Materials Compass: Materials Compass | Compare sustainable building materials | One Click LCA
